Marco Coppola
- UK
Hi, i would like to have a go at splitting the aerial signal to see how strong i can get the signal in other rooms. So i went in the loft(intrrnal antenna) and there is a cable that goes from the main antenna to an antenna socket downstairs, then there are 3 lose aerial end, 1 goes downstairs next to the antenna socket, 1 goes in the room upstair and another one in tge conservatory. So what i did is to put a 2 way splitter inthe socket downstairs the antenna cable that goes in the tv and the loose cable that goes back in the loft and plug tgat in into a booster and then plug the other loose ends inside the booster but the signal went bad everywhere. Any suggestions for me?
