Hello
My first post so hi to everyone!
I have a Stab HH100 with a 85cm dish which has worked fine on my DB 7000 for years.
After the 7000 died I eventually bought a DM800 and the stab immediately started to misbehave but intermittently: no chance of a full scan and occasional (but not always) movement towards east or west because it eventually lost the picture.
It would then be a nightmare to bring it back to Hotbird although occasionally you would turn the DB on and ther it was, back on Hotbird.
The strange thing is that I have a Technomate TM5000CI also connected (through a dual feed Invacom LN
This used to drive the motor without problems but now the Stab doesn't work with it either!
The Stab eventually got "stuck" at around 15 W I think and wouldn't move anymore. After several days trying I just had to get up there and untighten the bolts and turn the whole motor and dish towards hotbird.
I get a signal around 54% at its best (before was up to 95-96%) because the inclination of the dish is wrong (it was after all pointing to 15 W).
Can someone advise me on what to do to at least get a good signal on Hotbird as don't fancy changing the motor (if necessary) with gale force winds...!
