help with technomate tm1500ci+
ceefax1
help required,took technomate out of standby pressed channels up and down,red light flashed in front panel of receiver nothing works.used buttons on front of receiver still nothing.it seems to be stuck on eurosport cant enter menu nothing.switched off power for 5 mins tried again the remote and the buttons on the front the red light shows that the receiver is getting a signal but its stuck.any help appreciated.
thanks in advance
normally if i have any problems i always do this first.
if it doesnt fix it try loading the original firmware from the TM
site then press factory reset.
good luck.
