W william New Member My Satellite Setup sky dish My Location southwest devon May 17, 2013 #1 hi all just got new technomate tm-5402hd box having problems seting up no signal on tv just says no or bad signal can any one help plz
Lazarus Retired Moderator My Satellite Setup 80cm Motorised. Several small Dishes. Much else. My Location North York Moors May 17, 2013 #2 If you've attached it to the Sky dish mentioned in your profile, the first thing to check is the F connection.
satelliteman Administrator Staff member My Satellite Setup See signature My Location Northants, Midlands UK & Lanzarote, Canary Islands May 17, 2013 #3 Satellite and lnb configuration settings will also need to be set on the receiver. Sent from my iPhone using Tapatalk
W william New Member My Satellite Setup sky dish My Location southwest devon May 18, 2013 #4 hi thanks for the help i havent got a clue is the f connection the female connector from the sky cable and how do i set the lnb configuration settings
A A nonymous Member May 19, 2013 #5 I would suggest reading the manual that came with the receiver first The manuals supplied by Technomate are usually very informative for the newbie when setting up the receiver. If you don't have the manual you can find it by clicking on the link below. http://www.technomate.com/support/TM-5402%20HD%20Manual.pdf Nano
Channel Hopper Suffering fools, so you don't have to. Staff member My Satellite Setup A little less analogue, and a lot more crap. My Location UK May 19, 2013 #6 Is it a new, or old Sk y dish ?
