Help with TM1500
mick32
Newcastle
hi there i finally did it and invested in a box instead of a ss2 problem is im a bit stumped,,got the darkman image and put that on and latest softcam as far as i know but can still only get the free stuff,,can someone point me in the right direction as im losing hair rapidly,thing is im bald to begin with:-bash..anyways thanks in advance and oops if its posted in wrong section...
p.s forgo to mention i got hotbird,and the 2 normal astras...ta again
Well I do not have one of my own but from what I have read on the forum AFAIK you just flash with the patch, you may have to update the keys using the remote but there is no softcam used what softcam is that? and where did you try putting it?
After patch is loaded go to SYSTEM MENU and click OK then
if you can not see thc CAS, Type 2004 to turn patch on.:D
Hope this helps.
