Help with un packing and upgrading newcamd
timbo86
Dreambox 7020, CM 1.2 with invacom quad c120 & channelmaster feedhorn.
Belfast, Northern Ireland
Can someone basically explaing how to use the dreambox control center, Because my head is pickled!
What do you need to know..
well presuming your using an Hydra image, then by pressing the green button during normal TV operation, you will get a menu including at the top softcams and keys.
further down you'll see Hydra setup... in here you see the option of getting the latest control panel... get this then goto the previous screen and enter into softcams click and download NewcamD (latest version 5.25)
once done go into keys and download marys key bundle...
back once again in normal TV operation press the blue button and check that you are using NewcamD... if not then press left or right on the remote untill its displayed then press the green button to save settings
thats it :)
