help
U
uyanik
Likes
I HAVE UPGRADED MATRIX CAM BY LAPTOP USING
AND WHEN I PUT THE CAM IN THE RECIEVER DID NOT WORK AND THE FOLLOWING INFORMATION ABOUT THE CAM APPEARS IN THE RECIEVER
VERSION: DVB_CI_1.00
PROVIDER: G
AND WHEN I TRIED TO UPLOAD MRV 2.23 AGAIN I COULDN’T AND A MASSAGE IN MY LAPTOP APPEARS AS REINSERT THE CAM AND TRY AGAIN EVEV THE LAPTOP SEE THE CAM AND I SELECT PCMCIA CAM 0
I USED THE FOLLOWING SOFTWARE TO FIX THE PROBLEM BUT DIDN’T WORK AGAIN
PLEASE I NEED YOUR HELP
>COR<
>COR<
Likes
Sneek, HOLLAND
#2
First, try to set caps lock off, and write in undercase lettering, writing in caps is considered shouting and rude :)
Looks like you buggered up the updating of the cam, you need an cas2 or cas3 programmer to revive the cam.
With this you can always get the cam back to the software you want to put on it, PCMCIA methods are fine, but if the software is buggered, or you put MRB files on it you need an cas interface to reprogram the cam.
Cheers,
Cor.
