Hi I'm having a problem with my satelite system. I recently bought a sat beeper and when I set it all up to try and possition my satellite the sat beeper made no noise whatsoever. I have used a sat beeper with my sat before and it worked fine also my signal srength is static at 14% and does not even change when I position the the dish at the same angle as the other dishes in my area. Is it probable that the problem is my LNB its self and that my LNB is actually broken? Please help I am getting stressed.
