High Speed USB hub
This pc has been prompting me to connect using a high speed hub (works more efficiently I suppose).
What is it, and is there a PCI adapter available (for Win 98 or 2000) to turn this hulk into the Enterprise ?
The prompting normally comes from XP. I get it on my HP lappy as it only has USB 1.1 ports - quite frankly I wish I could turn it off as I KNOW that if I had USB 2 ports they would work faster!
Anyway, back to the question. PCI USB 2 cards are available. Seem to be about £10 - £15 IIRC.
jimbo
Retired Mod
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
Not sure that USB 2.0 will work on Windows 98. It may do on the last version but not earlier.
Anyway 1.1 runs at 12bits/sec and 2.0 at 480 bits/sec.
PaulR said:
The prompting normally comes from XP. I get it on my HP lappy as it only has USB 1.1 ports - quite frankly I wish I could turn it off as I KNOW that if I had USB 2 ports they would work faster.
Go to the top of the class, I was range experimenting with a spare drive that had Win XP and the wireless remote on it when the prompt came up, but the O/S is not my weapon of choice.
Will look in the parts bin for a USB2.0, unless somebody can throw a few names/cheap card my way.
Found one (and a weird one to boot)
Has four external ports, and one for inside the casing.
Seems to run fine on the XP o/s
Will try it later on the Win 2000
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
I have a similar
works fine on Vista :)
Results with the new USB port system
1) No extra range with the wireless link, so I think I'll be moving garages sooner.
2) I can bid a lot quicker on eBay,sometimes getting within 2 seconds of the finish time,rather than 10. As a result I have won a couple of motorbikes this month when polishing off the last of the wine.
(The wife will be happy)
