Hivion HD9090x ultima Problem!!!
placebo87
HIVION HD-9090x Ultima
Albania, Tirana
HI everyone!
does anyone know why my hivion hd9090x ultima doesnot recognise my dragon predator cam??? what to do?
please help...
thnx:toke:
placebo87 said:
HI everyone!
please help...
thnx:toke:
Did it recognize it before and now it doesn't or did you try this now for the first time?
Try to ask the manufacturer if this CAM is supported by this receiver.
Yes the cam is supported by the reciever.it supports even the dragon card...dont know what to do?:toke:
Hi placebo87,
has the cam ever been recognized by your receiver?
What message, if any, are you getting when you enter your receivers cam menu?
Which Predator version was last loaded onto the cam?
Have you ever loaded any Predator firmware onto the Cam?
What make/model card programmer are you using?
How long have you had the Dragon Cam?
What make/model cam have you got?
The reciever do not recognize the cam at all. it just says slot 1 slot 2....and i can not access the cam.I just got hivion hd9090x and i haven't loaded any other cam just i proved my dragon predator cam.i cannot tell you the exact firmware version of my cam it just says PREDMAKE...but i think it is the last version.
its possible to help me softcam for Hivion HD9090x ultima and the pin of the menu code.Thank you all.
Try 0000 or 1234
thank you very much but i want the pin to enter in the menu code,for example i want to write code of the premiere,polsat and etc.thanks
You can enter the kyes with a USB flash...create a _k_data.sgn ....copy paste the codes from softcam kyes ..softcam.bin...or you may find hivion kyes in the interenet.... insert the usb flash in ur recever and go to menu...USB transfer and press 1 from the remote... when it asks u if you want to transfer the key press YES.... hope is this you were asking for....:confused:
Just change the file type from _k_data.txt to _k_data.sgn...
I have attached the file here ==>>>
Attachment removed
Don't ever post keys or files with keys in on this forum, you have now gained an infraction, one more and it is an instant ban. Admin
If its not problem for you send me the atached files in my EMAIL REMOVED you very much for all.
