Hotbird through sky mini dish
The answer to your three questions is yes,yes,and yes again.It will work,but not completely,you should use a 60cm minimum for best results as some transponders are not so strong all over the uk............
Thanks for the reply dishdoctor, if possible I would like to avoid the expense of buying a new dish, my new reciever and CAM cost£200.
I live in Exeter, Devon. Do we have a good reception?
As Dishdoctor says, 60cm is OK, will be fine for 19.2 (as will the minidish), but for 13E an 80cm is better, or perhaps a Zone 2 minidish as you'll probably pick one up for £40 or so, there are loads of second hand dishes available if you look around..
