How do you fit coaxial cable into a corner?
AidyB
Wanting to setup syste to receive ART sports
Northern Ireland
My coaxial cable hangs slightly out from the wall, and I do not want to use those nail and clips things up the wall as place is rented. Anyhow, basically I would like to know how do you fit coaxial cable into a corner so that it runs up straight.
thanks for the read
Aidy
satelliteman
East Midlands, UK & Lanzarote, Canary Islands
Mini trunking will do it (16mm). Paint or wall paper over :)
EDIT: for internal that is :-rofl2
have you tried pvc tape :-rofl2 :-rofl2: :-lmao
wod
yorkshire
try some no nails sealant as i'm sure that would stick the cable to the bricks
AidyB
Northern Ireland
Rented mate so trunking out of question, well I could but its not to all tastes. Can I use pvc tape whatever that is, im sure its on *bay.
Would no more nails not leave a reasidue on the walls, or was that a joke :p
satelliteman
external or internal..... it wasn't that clear
4dbennett
lifes not a practice run
SPIDERBOX 9000HD, 1.2 and Humax Foxsat HD,Hitachi L500HDD
Acer Aspire 5315 Lappy
torfaen south wales
there are some excellent "velcro" wire/cable clips about now m8 try Wilkinsons, they have a few types in the phone/audio section, or on internet
regards dave
AidyB
Northern Ireland
Its internal. I Like the vekcro idea now, cheers Aidy.
satelliteman
I thought so as that's how I read it and then after thought you meant external :D
Park Royal
Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
So called capital of Suffolk, UK.
A small blob of "Blu:)Tack" every 6 inches should do the trick.
Or run "Pritt the non-sticky, sticky stuff" down the corner and press the cable to it.
Parky
streetlighter
Virgin V+HD XL Technomate 6800 Astra+Hotbird FTA on 60 cm dish
Cheshire
try some clear silicone for the cable works a treat. or self adhesive mini trunking that wont require drilling the walls.
