How moves my dish with crazyscan, my Diseqc 1.2 Motor or the USALS ;
JohnGr
Diseqc Motor with dish 1.10 - 42E - 30W.
Greece
How the moves with the crazyscan my dish TRIAX 1.10 with Diseqc 1.2, or with Motor the USALS ; I have a satellite PC card TT 1600, DiSEqC motor SG - 2100A with USALS, and a TRIAX dish 1.10.
Hello JohnGR.There are probably easier ways to do it.Though this is the way that I do it.First you need to set your lat and long position.Then I insert the satellite postition.then press goto x x.The other way though is to send the dish to the satellite that you wish to scan with your program ie DVBDream or if your dish is already on the satellite that you wish to scan, then just scan with crazyscan.
I've problem too in usals mode with crazyscan
if I put satellite position and then click to "move to x.x°" the dish don't go to the position I set, but in another...
I use tbs 6983
Have you set your longtiude and latitude in the Earth position box.
Moteck SG2x00 have some buggy USALS implementation. You can select SG2100 fix in CS Positioner console. DVBDream/AltDVB have selection USALS type (standard STAB-compatible and another non-standard like SG2x00 )
