How to get UK TV in Belgium?
Leee
Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200
47°N/8°E/490m
Sky Italia is purely rumoured to be 0pen
JTA
DM8000HD+DM7000S with PLi image, CCcam, movable dish 0.85 m, very happy indeed
Belgium
now that I think of it, there's a bug in Mary's PPanel - if you check your /var directory, you'll probably find 2 directories : /var/var/keys and /var/var/scce
this is wrong - you can delete these directories as they will never be used. Go to /var/etc/ppanel and edit the Mary xml file. Look for the "satan" line, at the end of this line you will find the following : "-C /var/;"
change this into "-C /;" and save the xml file. Satan will now be copied into the /var/keys and /var/scce directories, where it belongs.
use an unix editor to edit any dreambox file (best use DCC on your pc !).
have fun !
vlb_pds
DM 500
uk
I have CCcam 1.7.0 and Gbox 2.25 running but I have a problem now. When I switch to France4 on hotbird after few seconds picture appears (as normal)but then freezes and disappears, samething happens with multivision channels, cartoon network, boomerang, etc…. other channels such as BBC Prime, MTV France, Baby channel etc… are unaffected.
What could be the problem?............Please help?
JTA
Belgium
are u using cccam or gbox as emulator on TPS ?
it's been a few days since I checked my French channels, but everything was working then. You're not using cardsharing, are you ? If so the keys aren't being send on time. And no, I don't do cardsharing either, so can't help you if that's your problem.
CCCam should be working fine with TPS.
vlb_pds
DM 500
uk
I am using cccam on TPS. I do not do cardsharing either. It was working fine three days ago but not now.
May be it is due to updating cccam from v1.30 to 1.70?
Which is no doubt why Sky Italia are changing over to NDS v3 in the near future :p
vlb_pds
DM 500
uk
I have just read that TPS is black on all emu's. Is this correct? could anybody confirm this?
Has been for a few days mate.
vlb_pds
DM 500
uk
Is it possible to edit my sky viewing cards number in cccam/Newcamd and watch UK channels without inserting it into dreambox? if yes what would be the procedure?
No, you need it to be in the box.
vlb_pds
DM 500
uk
Reason for asking this that the sky viewing card I have is damaged and the chip is also very lose and does not stay at the right position. I am worried that it may damage the dreambox.
vlb_pds
DM 500
uk
Which image has good volume output? I have noticed that Pli and gemini both have much lower than my sky digibox box. Is there a menu setting to raise this?
vlb_pds
DM 500
uk
I mean a hidden menu setting?
mhku
TM Nano ~ sg2100
Midlands
None that I've seen. Just the volume button on the remote.
vlb_pds
DM 500
uk
I have heard that BSKYB has been hacked again recently (a research student from the UK university has done it). Keys are not available on the internet but you can get them from some small local tv/video repair shops in the East Midlands area. Is there any body aware of this?
