How to make a RS 232 cable for pc to coship?
hetalkom
ZENAGA STB ALL MODELS.
KAON ALL MODELS
AVAILBLE FOR DISH TV.
AHMEDABAD GUJRAT INDIA
Helo Freinds ,
I am from India . i wanna know how to install software using a rs 232 cable in a coship or any other receiver? i brought a new 9 pin modem cable but nothing worked.
can any one help me with the diagram of the same .
please note that i want to install/upgrade software from a receiver or pc...
what is the possible way ....
anybody from india or around world can help me?
i got all software from coship website, already.
thanks
my email is hetalkom*hotmail.com
hetalkom said:
Helo Freinds ,
thanks
did you get an RS 232 cable where the pins are in parallel, if so it is wrong.
It should be a NULL modem cable where the send & receive pins are reversed
Your cable should be connected like this:
2-3
3-2
5-5
And everything will work 100%...
HI Thanks for the reply ....
Yes ,,,,,i got it ... i helped me much ...
keep in touch ...i am from india
will be happy to be in contact with genious like u.
tell me more about u in hetalkom#hotmail.com
Regards,
Hetal
2-3
3-2
5-5
Hey thank you very much mmmm
i am able to get the point....
now i need somehelp to install software ,,,,
i lost a password for my winner sat digibox.....it is not the 0000 or the 1111 or like that.....
somebody changed it...how can i get or retrive it..
thanks keep in touch
