stevo
- Apr 2, 2004
- Age
- 54
dreamboxhd 800 pvr
2 x dreambox 500s
globalstar-m6 free to air
1 metre dish
80cm dish
60 cm dish
all via diqsec switch.
- england
once you have downloaded and unzipped all drivers and studio 4.6.1
Insert cam into cas 2.
press connect (contents of cam will be read).
press erase all (takes a few mins).
press wizard.
select cam (depending on what cam you have) ie matrix reloaded.
press file (browse for previosly downloaded bin file).
press open (this file will go into your flash file on cas 2.
press next at the bottom right.
press connect (little led will go green).
press next.
press write.
will erase again (always good to do another erase will clear cam properly).
wait for five mins or so to write onto cam.
press ok.
and all done,go and watch telly.
regards stevo
press wizard.
press next.
press write.
press ok.
regards stevo
