huseyin
- Next&nextstar Hd Minix cool blue
- UK
Hi first of all its my first post so greetings to every body.
my issue is about setting up the reciever but I dont know if I am in the right area. I would like to explain properly so that I may get the help I require. I live in the UK and moved to a new sets of blocks. Inside the blocks there is a socket which has SAT1 SAT2 SAT3 and a phone socket. So that means the dish is already installed all I need was a reciever. I brought a reciever (Next&nextstar HD minix Cool blue) and it only has 1 lnb input. I usually watch Turksat 42e so I use the SAT3 socket which I know SAT1 & SAT2 sockets are for sky & freesat. Now the problem arises here. Even though I use socket SAT3 by changing the port on reciever I used to easily pick signals from turksat & hotbird through 1 lnb. But then I brought a diseqc switch in order to watch Sky, turksat & hotbird. So I connected the diseqc with 2 inputs through sockets SAT1 & SAT3. sky works perfect via port 4 whilst Turksat works fine via port 3 but the hotbird stopped working (port2). Before the switch the hotbird & turksat was working fine via SAT3 socket but with port 3 (turk) port 2 (hotbird). Why doesnt it work when connected via disqc switch. Sorry for the long post but I would be grateful if some one can help regarding this issue. Thanks
