How to use DCC v.2.95 for Dreambox 800 se genuine
al_madhi
Riyadh - Saudi Arabia
Hi, ppl I have a genuine Dreambox 800 se HD and I installed a DCC v.2.95 in my laptop , I need somebody who knows very well how to use this programme in order to transfer CCcam.cfg file to my receiver , My receiver and my laptop both connecred together to modem by cables not wireless
I preferred if possible an eplanation step by step what do regarding this programme DCC
Best Regards
A,M.AL-Madhi
BM300
Dreambox 7000, 7020, 800HD
HD-USB
8 Dishes
UAE
  • Start DCC program,
  • select the connection type, through a router etc.
  • Enter the IP addres and the password used in your drambox and connect.
  • If all is correct, you should get a grean line.
  • If you get a red line due connection fault, your IP or password may be incorrect.
  • Once you have established conection, you will two panels.
  • Select the left panel of the program that shows your dreambox and click on /etc folder.
  • On the right panel, select the location of your CCcam.cfg file.
  • Click on the arrow between the two panels to transfer the file to your dreambox.
  • You can edit the file by right click on the mouse and selecting edit.
  • Do not forget to save any chages.
  • You may need to restart Enigma2 for changes to take effect,
