How to view card info on Dreambox
redout
1M Dish with Motek 2100,
DM 500 & DM 800HD, Vu+ Duo,
Digital+, Sky+, TDT, Saorview
Dublin
What menu do I enter to see viewing card/subscription information on a Dream 500s because I cant find it.
Thx
Thx
I use the PC to view card info.
Use browser like IE, type URL
_http://yourboxIP:16001
Select CCcam with the receiver blue button.
On the browser you should see info about the cards in the card slots.
Choose Entitlements menu.
If you are using the white card with newcs you will have to go to http://<dreamboxip>:8080 to get the info from newcs as CCcam will not show it. If you adjusted the httpd port in newcs.xml then you have to use the adjusted port. Same really applies for CCcam.
