Stevieray
- Humax FoxSat Freesat via a Sony Bravia KDL37 W5810
- Bromley, Kent
I've read through all the posts but my problem maybe slightly different. Most of the time for instance i can receive BBC1's HD channel but can only occasionally receive it's normal (non HD) channel possibly although i'm not sure, because the HD channel sends a stronger signal.
Just to say initially, i usually get a far better picture via Freesat than i do through the Freeview built into the TV although the signal may only last for a few mins or sometimes even last for a number of hours but then the picture starts to go and i eventually get the dreaded 'No or Bad Signal' message across the screen. Where my problem may be slightly different is if i play around with the connection at the back of the 'box' from the dish i can usually rectify the problem for a while until the signal decides to go again.
Do you think this is a receiver or a connection problem?
Many thanks.
Many thanks.
