HUMAX IRCI 5400 + ASTON SECA CAM
B
bamby100762
Dear friends, can anybody help me to find out what smart cards work best on my decoder?? I would like auto update card for seca and if possible auto update card for irdeto (stream is most wanted). Is it possible to see viaccess without viaccess cam?
Please reply.
w hole
uk
Not asking much then....
How about a 'Sod a turf with a bee a bugher on it' while we are at it.
It seems that Auto Update keys are very hard to come by, and I doubt that you will find any posted on the web because the providers change them if they find they are in common currency.
I think they are 'swapped' between users who have corresponding needs (e.g. I will give you my TPS if you give me your Cyfra+)
Can't help with the viaacess but I'm sure someone will have more info.
Good luck
W Hole
And to add to W hole's reply, what receiver are you using and with what Cams?
Rolf
B
bamby100762
I am using HUMAX IRCI 5400 with standard cam. I tried goldcard and funcard but it doesn't work on IRDETO (stream).
I had no problem with aston (i use goldcard).
Apparently Stream still has some channels in Irdeto (heard this from a friend)
nobbly
Not in UK
Why don't you try patching your cam?
nobbly :+
