i have some problem
B
bin20
Likes
hi all i need some help, when iam watching like mulivision and ather scrambled chnnle of course i use cam3 the last one i get lettel bit screen freezez it is not big problem but i want to solfe it this think couse i traied evry thing and i same think dont know what to do?
sonic1
sonic1
Likes
101
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
#2
Hi bin20! I always use camd3 also. Sounds like your tpscrypt is out of date.
What image and keys do you use?
B
bin20
Likes
iam using moltiboot image i have instaled two images in usb one gemini 2.0 and the next one is SDT Davinci4.img and cam3 the last keys from blue panel in the gemini
i also installed newcamd 6.01 and the last keys this one Newcamd keys vom 26.05.2005 and cam3 the last keys too this one Camd3-Keys vom 01.06.2005
costasd3
costasd3
Dreambox Emu Tamer
Likes
If it freezes at the beginning of the movie or whatever you are watching is because of going from FTA to encrypted
sonic1
sonic1
Likes
101
Black Hole Team
#5
I dont use gemini but do use sdt and found I had the same problem.
Try using hydra and download the latest keys and softcam.
If you want to still use sdt the copy the keys and scce file from hydra and ftp it to sdt.
I also find dbb 1.5 and the new nedkelly very good.
The new nedkelly uses the hydra cp!
B
bin20
Likes
ok i know hydra is good image but i have never seen this problem before when i want also ot game one it is kind shaking it shakes all the time i dont know but athers it is better than this chnnle so .
sonic1
sonic1
Likes
101
Black Hole Team
#7
Do you get a problem with FTA channels?
sonic1
sonic1
Likes
101
Black Hole Team
#9
Try update of keys from spartan 23/6/05
http://www.fookfiles.com/
Give it a try and let us know how you get on.
Good luck m8!
BGonaSTICK
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#10
The DaVinci4 image updates the FP and may not like the image you have in flash. Tried DaVinci Tertia? That's based on the official DMM1.09, and not the new unofficial beta as DaVinci4 is IIRC.
There is also a patch out for NewcamD 6.01. Don't know what it patches, but I've installed it!
There have been many problems recording MV's in recent weeks/months. It's well documented on this forum. Use the search function to find those posts. Think it's mainly due to the excessive loading that the 6.x series of the NewcamD put on the CPU. Not sure how the CAMD3 emu stacks up in terms of CPU loading.
STICK
B
bin20
Likes
i just instaled the last Spartan's Pack DB keys 23-06-05 and still shaking but the athers channles like motilvi is better than goma one, i also checked the gemini 2.0 image and it is same only game one freaking dont know what is wrong? by the way i instaled the last CVS in flash wich is rel109_1_[1].boxman-03062005.img evry think wroks good accept this problem
