I need help with EPG
J
james999
Dreambox cardsharing
Bahrain
I installed Gemini v3.40, but now I cannot see more than 2 hrs of EPG. In the previous version (v3.3), I used to be able to see sometimes a whole three days program guide. What to should I do to be able to see the extended program guide?
JTA
JTA
DM8000HD+DM7000S with PLi image, CCcam, movable dish 0.85 m, very happy indeed
Belgium
you're not really telling us a lot, are you ?
for Sky, you'll probably need some plugin installed to get it's epg.
for Canal+ and DISH, you may need to change some expert setting of gemini, allowing it to interpret the embedded EPG data of these systems.
if you're using MV to display your EPG data, you might need to include some input sources in the MV input sources configuration page.
J
james999
Bahrain
Well, it is the case for all channels. I guess It has something to do with Gemini v3.4. If you want me specific channels then Showtime, Nova, Orbit, TPS, and ABSAT.
