I need Major Help
NioX
I bought a Digital Satelite Receiver, it says it is a SMART my dealer calls it the SMART M5 receiver and thats what it said on the box. It works very well and has an embedded cam.
My dealer also gave me a free Smart Card on the front it says Open Platform,
and on the back AT90 (Purple).
Anyway. I searched the whole box and the manual and it doesnt give me a technical support numbers or anything anywhere.
all I could find was the Firmware
STB: DCI-5000F
HW: 14770-60 1.20
SW: D_ECI CAS 1.20
I am wondering if someone can help me know what Company makes it so I can updates.
Where I can buy an RS 232C cable if I need it or not that is
What My card is and how i can update that.
Thanks a lot your Newbie Friend
