I want measurements channel master 2.4m dish offset
Midosat
Nilesat
Algerie
Hello, I want to measure the arms and the focal length, please
Channel Master offset
244cm x 264 cm
There is a mistake I have, there is no upper part of TOP. the two halves together BOTTOM
does it fit
No.
Who did you buy it from ?
(somewhere else there is a person with two wrong halves)
RimaNTSS
Some SAT-related hardware.
N-E from Riga
@Midosat post some pictures of what you have.
RimaNTSS
N-E from Riga
For sure, antenna made out of 2 bottom parts will not work as it should do. You better ask the person from whom you got this antenna to provide you with the upper part. Or find the person nearby who got 2 upper parts of the same antenna.
Ups.... I did not see the picture in the first post, sorry.
mickwig
90cm Astra1 dish;
244cm x 264 cm
does it fit
Looks the same. The difference seems to be the holes on the side for the LNB holder.
Also, the top part has nothing attached to it. All fittings are on the bottom. So the arms etc. should be OK.
RimaNTSS
N-E from Riga
should be OK.
You can probably catch some signals, but you will never get such a dish performing as 2.4m. The curvedge of the upper part of the offset antenna is different from the one the bottom part has.
nelson_b
Contributor
I agree RimaNTSS .... the curvature of the top piece is slightly different i think ...... see pics of bolt holes
top one is 11cm deep .... bottom one is 9.5 cm
RimaNTSS
N-E from Riga
In two words: The upper and lower parts will have the focal points at different places, not in one as it should be.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
A littlebit off-topic:
Out of curiosity, I wondered: what would happen when you would only use such a bottom half, for reception? As that would give the best result, when you don't have a top half, I reckon.
I just calculated: the 'new' dish would have height 1336.3, and offset angle 12.6 degrees (dish height opening angle towards focus: 48.1 degrees). Bottomstring stays 1460, topstring would be 1752.
Distance Top of dish to G-spot: 718, Focus to G-spot 1527.
So it would function as a 130cm dish, but a 'normal' feedhorn would give great spillover losses, I'm afraid. Not to recommend.
However, when you have no other dish available, and are in urgent need of some sort of satellite reception, you could try it that way, and experiment...
Back on-topic:
I hope you can find a top half somewhere!
Greetz,
A33
mickwig
90cm Astra1 dish;
Jump, looks like it ain't the same!!!
Are the top and bottom half the same size or not?
No.
mickwig
90cm Astra1 dish;
Midosat
Nilesat
Algerie
Hello. Yes, the upper part and the lower part are not the same size, unfortunately I have to look for the upper part
Good. Now that is cleared up......
Midosat
Nilesat
Algerie
I am from Africa far from you I just wanted to ask because you have experience and skill
Yes, I know.
Midosat
Nilesat
Algerie
Yes, I know.
I bought it used, not new, from someone who has had it for a long time
The first image confirmed it was used. Did your supplier have more than one dish for sale ?
