Mint condition, 7 month old Icecrypt (this is one of the Fortis stable of receivers - also available as the Octagon 1018HD at a much higher price). 2 card slots available on this version and 1080p MKV playback on the latest firmwares which is currently updated once every couple of weeks or so. Runs CAM and EMU plugins.
Great picture, record 2 channels at the same time and other features (see below for full list). Very reliable and good value twin tuner HD receiver. This works fine with BBCHD and ITVHD although it should be noted it is not an officially badged Freesat receiver.
Fully boxed with all original documentation, warranty and cables, unused remote.
£189 with no HDD (add your own or use external/USB stick)
Price includes standard mainland UK courier p&p (extra for any other location)
Full official spec:-
- Twin Tuner HDTV PVR Receiver ( H.264/ MPEG4 HD )
- Supports MPEG4 /MPEG2 - HD/SD, DVB-S2 /DVB-S
- Supports NAS recording
- Embedded Linux OS & Ethernet port
- Time Shifting, Recording & Playback with Internal HDD (SATA) / External HDD (USB 2.0)
- Simultaneously Records of 2 Services and allows Watching 2 others (PIP)
- Powerful Extended EPG supports and Event Recording
- Two USB 2.0 Host ports (MP3 Player & JPEG Viewer)
- Xvid file play back supported
- Ethernet port Supported
- Intelligent Blind Scan for both SD and HD TV & Multi-Satellite Search
- Premium Grade White VFD Display (12 Digit Alphanumeric)
- Premium Grade Universal remote control unit
- Multi-LNB Controlled by DiSEqC Control Version 1.0, 1.1, 1.2 and USALS
- On-Screen Display with Full Color & Resolution
- Favorite Groups
- Powerful Service List Manager for Favorites, Lock, Skip, Move, Edit and Delete
- Service Sorting by Alphabet, Transponder and CAS
- User Friendly & Multi-language Supported (OSD & Menu)
- Teletext / Subtitle Supported
- Maximum 10,000 Services(TV & Radio) Programmable
- Picture-in-Picture (PIP) & Multi-picture Display(*)Parental Lock / System Lock / Installation Lock
- HDMI Video & Audio Output (576i, 576p, 720p, 1080i)
- Supports Y/Pb/Pr(component) Output in HD
- CVBS(composite) Video & Audio Output via RCA
- CVBS, RGB, Y/C Video & Audio Output via TV SCRAT
- Optical Output for Digital Audio(SPDIF)
- MPEG-II Digital & Fully DVB Compliant
- Software & Service channel Database upgrade via USB & RS-232C port
- 2 Smart card readers and 2 Common Interface Slots
- 1W Stand-by Power Consumption
