Impressed with Cheap DVB-T2 stick
Yes remlap. I've tried a couple of other firmwares too to no avail.
Seems to work OK on the Raspberry Pi, so if all else fails, there's a generic tarball I could try here -
http://openelec.tv/forum/71-pvr-live-tv/74370-build-with-geniatech-t230-support?limitstart=0
Fisty McB
See my signature...
County Tyrone, N. Ireland
That USB tuner looks like a couple I have that have the RTL2382T2 chip - they can be used on Enigma 2 receivers for an additional DVB-T2 tuner. IIRC Black Hole has the drivers installed automatically while for Openvix it can be downloaded in the plugins section in the firmware. It's also one of the workhorses of a lot of budget SDR set ups. For its cost and performance, there's not a lot to be said against it - it doesn't compete against say a commercial £500+ SDR package but no one should expect it to either.
remlap
Wales
Been tinkering with TVHeadend, The stick seems to be registered and first time I booted with TVHeadend the Raspberry Pi recognised both demodulators. But whatever I try the damn thing won't scan anything in. I gave up and plugged it back into my windows system and removed TVHeadend.
Adam792
Cheltenham
If it's a first generation Pi that's probably because it doesn't provide enough power to be able to tune in the stick even though it recognises it (I've had this problem before with a PCTV 290e).
You'd have to use a powered USB hub to get it to work (or the newer Pi2 which I got at Christmas and seems to manage to power the DVB-T2 stick just about alright with the 1.5A USB charger plug I'm using).
Sent from my iPhone using Tapatalk
remlap
Wales
I'll try to scrounge up a powered hub. It is the Pi2 though. I can see myself giving in though sadly. I don't have much use for a TVHeadend setup on DVB-T2 anyway being Freeview Lite.
2016-01-11 15:19:32.903 mpegts: 626MHz in Blaina - tuning on Realtek RTL2832 (DVB-T) : DVB-T #0
2016-01-11 15:19:32.903 subscription: 0002: "scan" subscribing to mux "626MHz", weight: 6, adapter: "Realtek RTL2832 (DVB-T) : DVB-T #0", network: "Blaina", service: "Raw PID Subscription"
2016-01-11 15:19:37.000 mpegts: 626MHz in Blaina - scan no data, failed
2016-01-11 15:19:37.000 subscription: 0002: "scan" unsubscribing
Well I have the August 210v2 working at last in Linux - of a sort, in that I'm tuning an individual channel with another DVB app, dvblast. So maybe w_scan isn't tuning each channel precisely enough?
david@david-P35-DS3 ~ $ dvblast -a 0 -f 498000000
DVBlast 2.2 (release)
warning: restarting
debug: using linux-dvb API version 5
debug: Frontend "Silicon Labs Si2168" type "OFDM (DVB-T)" supports:
debug:  frequency min: 55000000, max: 862000000, stepsize: 0, tolerance: 0
debug:  symbolrate min: 1000000, max: 7200000, tolerance: 0
debug:  capabilities:
debug:   INVERSION_AUTO
debug:   FEC_1_2
debug:   FEC_2_3
debug:   FEC_3_4
debug:   FEC_5_6
debug:   FEC_7_8
debug:   FEC_AUTO
debug:   QPSK
debug:   QAM_16
debug:   QAM_32
debug:   QAM_64
debug:   QAM_128
debug:   QAM_256
debug:   QAM_AUTO
debug:   TRANSMISSION_MODE_AUTO
debug:   GUARD_INTERVAL_AUTO
debug:   HIERARCHY_AUTO
debug:   2G_MODULATION
debug:   FE_CAN_MUTE_TS
debug: tuning OFDM frontend to f=498000000 bandwidth=8 inversion=-1 fec_hp=999 fec_lp=999 hierarchy=-1 modulation=qam_auto guard=-1 transmission=-1
warning: failed opening CAM device /dev/dvb/adapter0/ca0 (No such file or directory)
debug: setting filter on PID 0
debug: setting filter on PID 16
debug: setting filter on PID 17
debug: setting filter on PID 18
debug: setting filter on PID 19
debug: setting filter on PID 20
error: no config file
debug: new PAT tsid=8194 version=7
debug:   * NIT pid=16
debug:   * program number=8258 pid=1700
debug:   * program number=8325 pid=1800
debug:   * program number=8330 pid=2000
debug:   * program number=8357 pid=1900
debug:   * program number=8384 pid=1100
debug:   * program number=8385 pid=1500
debug:   * program number=8442 pid=1400
debug:   * program number=8448 pid=1300
debug:   * program number=8452 pid=1200
debug:   * program number=8500 pid=1600
debug:   * program number=8600 pid=3100
debug: end PAT
debug: new SDT actual tsid=8194 version=13 onid=9018
debug:   * service sid=8384 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="Channel 4"
debug:     - desc 73 unknown length=16 value=7777772e6368616e6e656c342e636f6d
debug:   * service sid=8442 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="More 4"
debug:   * service sid=8258 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="ITV"
debug:     - desc 73 unknown length=11 value=7777772e6974762e636f6d
debug:   * service sid=8448 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="E4"
debug:   * service sid=8325 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="ITV2"
debug:   * service sid=8452 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="Channel 4+1"
debug:   * service sid=8357 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="ITV +1"
debug:   * service sid=8500 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="Channel 5"
debug:     - desc 73 unknown length=11 value=7777772e666976652e7476
debug:   * service sid=8385 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="Film4"
debug:   * service sid=8330 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0x1 provider="" service="ITV4"
debug:   * service sid=8600 eit_schedule eit_pf running=4
debug:     - desc 48 service type=0xc provider="" service="Freeview Information"
debug: end SDT
debug: frontend has acquired signal
debug: frontend has acquired carrier
Next is to come off the command line stuff and try a GUI app like updatelee's dvbupdate. That works fine with DVB-S/S2 with my Skystar Xpress pcie card, but doesn't tune any channels in with my TBS6220 DVB-T/T2 card, so I'm not hopeful. First though I have to recompile dvbupdate, as I've lost QT compiler since a Mint upgrade :mad:
OK, I have updatedvb GUI compiled with Qt again. It's the first time I've managed to get any DVB-T/T2 items working with updatedvb, either with a pci card or USB dongles. Always only DVB-S/S2.
This is with the PCTV 290e, BBC2 DVB-T2 ch.474. The August T210v2, although recognized in updatedvb, still obstinately refuses to tune channels.
Seems there's some work to be done with signal quality / BER indications.
remlap
Wales
Been a year but finally gotten this tuner working under Ubuntu 16.10.
Screenshot from 2017-02-26 20-54-58.jpg Screenshot from 2017-02-26 20-55-38.jpg screenshot C4HD.jpg
Paxman seems enthralled anyway.
