In Light of the Recent Fuel hatred
there are people out there converting two and four stroke engines to steam
I prefer the idea of a wood-gas generator, less chance of blowing up, less modifications needed to an engine... :D
Just use compressed air, a scuba tank may get you to the store and back.
I saw somewhere that a guy built a car engine out of stainless steel and used hydrogen and oxygen as fuel, the waste product was water, (no outside air was used) thus the need for stainless steel.
The bad part was that the hydrogen kept escaping the tank, this due to it leaking through the sides of the gas cylinder, so it had to be a rear engine design with the hydrogen tank up front, this also turned out to be a bad design as the car crash experiments all wound up exploding.
Look up Smokey Yunick's hot vapor engine that is a neat engine to build.
