Incorrect audio from RF Out
C
Coca-Cooper
A weird one!
Amstrad DRX400 Digibox connected to my TV via the SCART Cable - No Problems!
A second decoder (Strong 4100 - for BBC Prime) connected to the Digibox through the VCR SCART socket on the Digibox. So far, no problems, I just turn on the BBC Prime decoder and I can watch (and hear) everything on my TV.
BUT:
If I connect a coax cable to either RF-1 Out or RF-2 Out so that I can watch the channel on a second TV this is what happens:
- Turning on the Strong Decoder, I see the picture for BBC Prime on the second TV, but the audio is whatever is playing on SKY. On my main (SCART) TV I see BBC Prime Picture AND audio
- Turning off the Strong Decoder, SKY channels play fine (correct picture and audio)
It seems like the RF curcuit recognises a change in signal source only for the video, but not the audio.
I've used the {Service,4,0,1} menu to change the RF channel, but no luck.
Any ideas?
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
Try going into digibox menu and turning off scart control,and if there is a secind scart socket on your strong try that one
C
Coca-Cooper
Thanks Zorba, but still no results.
My Strong Box has three SCART sockets on the back (TV, AUX and VCR), but only the TV socket appears to output any signal.
Also, after fiddling around the back of the Strong Box, found out it's a a 4300 not 4100 D'oh!
Do you think it's a "software issue" on the Digibox??
Operating System: 1.2S4Bq
EPG Software Ver: 3.1a.6
This sounds like a priority problem with the TV, the audio through the SCART is taking priority over anything that runs RF.
Which TV is it ?
C
Coca-Cooper
Which TV is it ?
Sony KV-32FQ80
I tried disconnecting the SCART from the Digibox going to the TV. Still the same problem happens on the second (RF) TV.
OK, let me get this right, do you have the Strong receiver in the RF loop, or is it purely connected via the scart to the digibox?
C
Coca-Cooper
Strong Receiver connected to the Digibox via the SCART.
Coax connected to the Digibox.
Strange, the only thing that should leave the RF outlet is anything introduced into the RF loopthrough and the picture/audio of whatever is showing on the digibox itself, but not anything that is connected by scart. Sounds like some sort of bleed over.
Zorba
So ,if you switch off the digibox,the bbc prime sound comes back?
C
Coca-Cooper
If I switch off the Digibox, no audio or video is sent from the RF outputs. For the scart TV I can watch (see and hear) BBC Prime if the Digibox is first turned off.
I may be grasping entirely the wrong end of the stick here, but are you saying that you want to be able to watch BBC Prime from the Strong, through the 2nd RF output of the digibox, but with only the scart connection from the Strong and no RF connection between the two?
C
Coca-Cooper
Yes.
To recap . . . . . . . .
Strong connected to the Digibox with a just Scart cable. Digibox connected to two TVs:
- One via Scart (Both SKY and BBC Prime work fine, ie picture and audio)
- One via the RF Out (SKY works fine, but BBC Prime has the audio of SKY)
That's what I thought, in which case BBC Prime shouldn't actually work at all on the RF out, the digibox is not designed to work like that. To see the picture and video from the Strong via the RF out, you will need to loop the Strong RF through the digibox.
C
Coca-Cooper
CONFIRMED!!
Just swapped my Amstrad with a mate's Panasonic DSB-20 and now only SKY works on the RF Out TV (regardless if the Strong box is turned on and showing BBC Prime on the Scart TV).
Panasonic:
O/S: 1.2S4Bq
EPG: 3.1.a.5
Amstrad
O/S: 1.2S4Bq
EPG: 3.1.a.6
Zorba
What if you bypass the digibox,eg connect the rf in and out leads together?just to confirm the strong is okay.
C
Coca-Cooper
The Strong box is fine, as it used to supply both a Scart and second (RF) TV before I got the Digibox
Zorba
I give up.Let us know if you sort it out,its got me baffled.I've got to be there to try and work it out. :(
