Installing & activating a USB flash drive
adamrick
DM7000, DM800, OSN PVR, MCA PVR,
Dubai
Hi HB13DISH,
Can you answer another question for me?
How do I activate a USB flash disk inserted into the USB slot on the back of the Dm7000?
I need a bit more disk space to store EMUS, cams and stuff and read in these forums that you recommended a USB flash disk for more space...
Can you help once again? Thanks!
Do you have a copy of FlashWizard Pro 6.3? If not grab it pronto and use the config/utilities tool in it to format the flash drive.
You will need the DB set up on your lan.
I have downloaded Flashwizard 6.3 today....
I assume I must have my laptop and DM7000 on the same network, and then flashwizard will connect to the Dbox and format the flash disk in situ?
I also have DCC for uploading images and ftp connections directly to the Dbox via my LAN.. will that also work?
