Inteference/Distortion due to HH Motor
Likes
Technomate 1500CL
Moteck DiSEqc SG2100A
#1
Have Technomate 1500CL+, this all works fine with 80cm dish and Sony digital TV.....
And now added Motek SG2100A (DiSEqC H-H motor)....the result ?
The video output of the Technomate is distorted and loss of colour (i.e. on the menus). Any idea what is going on ? - looks like some sort of inteference problem - note, I have this problem when motor is on standby.
I have tried:
1. Different SCART leads from Technomate to TV
2. Different TV's
3. Unplugged the normal teriastial aerial
But nothing changes...
I am wondering if the Technomate has the power to drive this motor ??
Ta
Phil
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#2
The STB should have no problem at all driving the motor.
It sounds a really odd problem. The picture returns to normal if you then reconnect direct to the LNB?
All I can suggest is that you simply bypass the motor by inserting a female to female connector instead, and this should test all your F connections as well...
Does the motor rotate correctly when commanded?
If everything else checks out, I can only think that it's something inside the motor. Problems have been reported in the past due to poor suppression, but only when the motor is actually driving.
Likes
Technomate 1500CL
#3
If I "take out" the motor everything works OK.
It looks the motor (i.e. motor + electronics) is simply intefering with the STB.
P
BGonaSTICK
Likes
Brighton
#4
Mmmm, looks like you have a bad one. Where did you get it?
