DX Excalibur
- 3.0m PF dish C&Ku band 103E-40.5W/1.4m PF 75E-37.5W, DM 500HD,TBS 5925/6903
- RO, near Bucharest
Hello!
In the last days I have tested this 2 lnb's. I have modified the inverto black ultra lnb to have the exact dimensions like the Black Pro flange lnb. I have tested them on different sattelites and different transponders.I have buy all lnb's with 2 outputs, because I have see from the white tech lnb's that the single version is weak, and the twin white tech flage have with up to 1db more better signal then the white tech single lnb on the whole band.
I have made the test with my 1.4m Fe prime focus dish, Dm500 HD receiver and only 5-10 minutes between switching lnb's. Signal is in db's and from what I have see, the ultra lnb perform better in the band 11700-12750 with up to 0.5db better signal then black pro for dvbs transponders and more then 0.5db for dvbs2. In the band 10950-11700 signal results are same for both lnb's and for 10700-10950 the black pro has an advantage on horizontal transponders, and for vertical signal is nearly the same with a little advantage for the Black Pro.
Inverto Black Ultra/Inverto Black Pro
Thor6 K1 spot:
10788 H - /6.90
10809 V 7.70/7.85
10809 H 6.85/7.30
10841 V 7.30/7.45
10841 H 6.65/7.05
10873 V 7.45/7.50
10873 H 6.80/7.15
10934 V 7.00/7.00
Nilesat 201
11727 H 5.50/5.50
Astra 1H
11798 H 8.50/8.00
11836 H 5.75/5.20
11954 H 8.65/8.10
12032 H 8.60/8.15
12051 V 8.85/8.20
12207 V 9.10/7.95
12266 H 8.30/7.65
12344 H 9.00/8.55
I will test it also on my 3.0m prime focus to see the difference between this two lnb's, and write here the results.
Thor6 K1 spot:
10788 H - /6.90
10809 V 7.70/7.85
10809 H 6.85/7.30
10841 V 7.30/7.45
10841 H 6.65/7.05
10873 V 7.45/7.50
10873 H 6.80/7.15
10934 V 7.00/7.00
Nilesat 201
11727 H 5.50/5.50
Astra 1H
11798 H 8.50/8.00
11836 H 5.75/5.20
11954 H 8.65/8.10
12032 H 8.60/8.15
12051 V 8.85/8.20
12207 V 9.10/7.95
12266 H 8.30/7.65
12344 H 9.00/8.55
