Is Sky Digi Compatible with PCTV Cards?
NZPilot
I am about to have Sky Digital (London) installed in two days, and have yet to purchase a TV set, as I am considering all the PC TV Card options out there.
My question(s) is this:
Does Sky Digital work on most/all TV Cards?
If not, do you know which ones do work with Sky Digi?
I would guess that most PC TV cards would work with a Sky digibox, if they have a video and audio in then you should get a better picture though, than you would using the RF in.
rolfw,
I have since bought the WinTV-DVR-250 and installed it on my XP Professional op sys.
I was told by 'they' that some tv cards did not support sky digital, hence the question.
I have encountered my first problem. When I use the record function, and select load/play, it crashes on my XP Prof version - not sure if I need an updated driver etc, but will look into it.
Hope this is not the first of many heartaches.
Thanks for the reply. Much appreciated.
