Jaeger 1224 H-H motor
CROSSBONES
S.Wales
I am looking for a Jaeger 1224 H-H motor:)
olisun
, Fibo Gregorian 1.2mtr, Skystar 2
Hounslow
how much are you looking to pay? :)
CROSSBONES
S.Wales
I can get a new one for 116 euro`s.
-http://www.satshop24.de/satshop24_s/36_v_motoren_h2h_mount_36v_motoren_einse.html
Has your 1224 been installed out side?
Was thinking around the £50 mark mate?:)
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
Hello!
what antenna you want to install on this motor?
some modells needs special adapter plate,that are not included in the normal motor (standaloneprice)
CROSSBONES
S.Wales
Im going to install my Fibo 1.2m on it Turok.
Im going to use the channel master adaptor plate.;)
CROSSBONES
S.Wales
How much did you have in mind olison?
Maybe a part x with my Fibo mount?:)
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
okay,make some pictures,what do you have exactly modifeized on the plate?
CROSSBONES
S.Wales
Nothing yet! Im after the 1224 H-H motor 1st!:)
olisun
Hounslow
The problem is I don't have the heart to sell it for so cheap as the shipping itself would cost me around £15-20 and my current Fibo motor is showing signs of oldage as I am loosing positions on my sats even if I keep the receiver switched off for days...
I always wanted to install my Fibo on the 1224 but the problem is I don't know anybody who can make the adapter plate for it...
CROSSBONES
S.Wales
If its new condition and not been installed out side, I can go to £60 and my fibo mount.
You would not have to post as I could pick it up, as Im up in Oxford often. Only an hour away from you.
If not im going to order from the German company.
No worries mate, totally up to you.:)
olisun
Hounslow
That is tempting...:-rofl2
Do you have a picture of your mount?
olisun
Hounslow
If you got the motor with the mount then I how about
Your mount with motor = £75 + My 1224 + CM Adapter plate?
But I am off to paris the next week for 5 days and will be returning back on Friday
CROSSBONES
S.Wales
Thanks, but no thanks mate, think ill order a new 1224.:)
cheers,
CB;)
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
also you can order the adapter plate what you dont have,ask satshop24 maybe he can make one for you!
this motor is also now out of production does jager in taiwan stop there complete production?
CROSSBONES
S.Wales
I have now ordered the 1224 with c/master adaptor plate.
£120 delivered! from Germany.
I will have no problems making extra adaptor plates. Maybe Ill make a few and flog them;)
Want me to put you down for one olisun?:)
olisun
Hounslow
It makes sense to buy a new motor rather than buying mine as I wouldn't want to sell it for less considering I paid a lot and you wouldn't want to spend more for an "second hand" motor...
I would love to have the adapter plate but it all depends on the cost...:):)
Turok
1,25 Fibostop
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Austria
does you fibo motor stop working? i have used modell and new modell here!
yes the iraon prices rise up the last couple of month 26 % because the chinese buy more iron then all the european countrys together,i heard in austrian radio!
CROSSBONES
S.Wales
Just a donation to the board would be ok;)
Yes but i am ordering the part from snuffer, i have 3 fibo moto`s all with the same fault, dish moves a little, and err2 on the vbox.
olisun
Hounslow
Are you going to make the adapter plate as same as the CM adapter plate??
Is it going to be heavy as the CM adapter plate?
The reason I am asking is because my dish is up on the wall and I am sceptical about adding more weight to it as the motor is already heavy and the CM adapter plate also weighs a ton...
