Jaeger Smr 1224 motor
zonerc
Currently Sky minidish with a Zgemma H2S
Stoke on trenr
Wanted Jaeger Smr 1224 motor and plate to fit a Channel Master 1.2m dish
Thanks in advance.
Mickha
North West
Yes, I'm using one on my CM 1.2M.
You will also need a v-box II positioner, if you can get hold of the Jaeger 1224.
They stopped making them some time ago, but they occasionally pop up with second hand dishes.
zonerc
Stoke on trenr
Yes thanks the V box is more available if I can get hold of the jaeger.
Was thinking of the polar mount instead but there doesn't seem many of them either apart from on sss new and expensive.
Archive-8
Gibertini make a good polar mount, it's for there 1.25&1.50 dishes.
zonerc
Stoke on trenr
Will they fit a channel master though only just getting into it and the dish will be on a ground stand?
You'll need to make a plate most likely but it's only drilling 8 holes...
zonerc
Stoke on trenr
Cheers for that Jack
Maybe a opton if I can't find the Jaeger 1224 or channel master polar mount.
Willing to look at something that may need a little work as I could probably get it shot blasted at work and painted.
zonerc
Stoke on trenr
Thread can be closed thank you admin as I'm all sorted.
Roy
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I think he got a polar mount from another thread but yes, pictures are mandatory
