Keys via remote control
haggag
I have found an excellent little program called: Downloader 2.5
Whenever any of the encryption codes change, I connect to the Internet and run Downloader 2.5. In a few seconds all the changed channel keys are downloaded :) .
My only problem is how to use the downloaded keys to update my CAM using the remote control )(-red .
I accidently learned that when I receive the Polsat 13E Nagra Key "***********************", I would use the remote control to enter "**********************" instead. I don't know why, but it works. However, I have no clue on how to enter the other Nagra,Seca, Viaccess, and Conax codes using my remote control. Can anybody explain/help pleeeeeeease.
Ossama Haggag
Keys removed by admin, please observe the rules.
vieira
Can you tell me please where I can get this Downloader 2.5
Thank You
I accidently learned that when I receive the Polsat 13E Nagra Key "**************************", I would use the remote control to enter "***********************" instead. I don't know why, but it works. However, I have no clue on how to enter the other Nagra,S*ca, Viaccess, and Conax codes using my remote control. Can anybody explain/help pleeeeeeease.
Ossama Haggag
Moschino
you can get this downloader 2.5 from here mate
_http://download.skystar2.cz/default.asp?str=sou&s=46
i just downloaded it gonna see whats it all about
haggag
Thanks to all who have viewed my original post. But, doesn't anyone have a reply to my simple query regarding how to enter the codes for various encryption systems via remote control? For Nagra, I enter 700 100 xxxxx. But what about the remaining Viaccess, Seca, Mediaguard, etc...?
Best Regards to all,
Dr. Ossama Haggag
aries
can u get the abs-cbn new key with that too..
more power
mtiqbal
I think Hex-Decimal convertion is involved. Since both keys are not visible so I can not make it sure. Do you know Hex-Decimal convertion?.
patrick
i've just tried a new receiver from ICE, you can key in the codes in Hex on RC - clears quicker than MR. press help button and key numbers to update it.
warpchild
Hi all,
First thing i have to say is that this forum is great,keep it up guys.
I would like to know how can i convert the hex to remote keys with a kind of software,and secondly is it possible to enter seca keys by remote?
nhf11sa
Hi All.
I hope someone can help me find S/W for My Arion AF-8100ci or wher i could
find some websites with Arion S/W
KeithD
Hyde, Greater Manchester. U.K.
Dr. Ossama Haggag
Try the sientific calculater from Windows.
Press the HEX button and enter the 2 hex digits.
Then press the DEC button and read off the converted numbers.
You may have to put in leading zero's
Keith
haggag
ash7aq said:
I found a trojan in this software by my antivirus programme
Yes, downloader 2.5 has a virus in it. My NAV discovered it also. There is another program for updating the keys via the Internet, but I cannot remeber its name. Could anyone help?
svpmohan
Multi Lnb dish, pointed to Astra1 &2, Hotbird and 23°.Dreambox and one FTE receiver.
Belgium
The downloader has a virus, do you know any better one?I know how to update the keys with the remote control. If you still need send me a mail.
I accidently learned that when I receive the Polsat 13E Nagra Key "***********************", I would use the remote control to enter "**********************" instead. I don't know why, but it works. However, I have no clue on how to enter the other Nagra,S*ca, Viaccess, and Conax codes using my remote control. Can anybody explain/help pleeeeeeease.
Ossama Haggag
mani
Hi every body,
i can tell about the using of the remote control entry for different enc sys.
First u need to know some cheat code of the Rc"remot cntrl" buttons for your type of reciever specially when it's an embedded decr sys. Secondly you should have to know the indent of the hex code will be entered and also, its index.Indent will be 6 digits number, index is 2 digits number, and the hex code to be modified.Last thing is to save your changes and use the codes.
kyklopas
I would like to learn how to punch in keys in Humax 5400 using the remote control.What software is needed to get the keys and step by step instruction.Until now i am using funcard 2 and 6-1 files.My humax has ToH3.1.
sammi60
can any one help decode multivsion and xxl on g-guard receiver?
MaxPlus9300
Please tell me where should I download the downloader to. In my PC hardware of the Satellite reciever....? Thanks ..... this for Dr. Ossama Haggad
