Hi there
I have an Extreme PVR with embedded Magic Cam which I think I've killed after sticking in Penta 1.11 ( yep..silly but some posts seem to say OK now)
Now its says no Cam installed, but worse than that it will not find any chanels at all. I've pressed all Factory reset buttons I can find.
Its finding the Sats fine as the signal strength/quality are as good as they always were but it finds no channels at all.
Questions :-
1/ Is my box just dead now ie no channels not even FTA
2/ is there a way to fix this at least to get FTA ( ie DSF for the GPs )
3/ can it be fixed using the Cas 2 thing
4/ looking at the pictures of the CAS2 it seems the CAM plugs into it rather than the it into the CAM so how does it work with the embedded CAMS.
5/ can I just get say an XCam, install and all will be fine
sorry for so many questions but I'm at the point of saying do I need a new receiver and they cost a bob or two....
hope you can help
Neil
Questions :-
hope you can help
Neil
