Kiosque problems
tirosh
Echostar AD3600IPVA
Channel Master 1.2M
VxMulti, MM1.04
Essex
I am having problems with the Kiosque channels. I have an Echostar AD3600 with an Aston 1.05. I have programed my GW card using the secanix/GBOX files and although these channels open up they :
- close and open all the time
- image breaks up and then recovers again
Is anyone else having these problems? Is there a way of fixing it?
Tirosh.
Only thing i can suggest is to try a different file, I had problems with Kiosque initially, but find the Strsh files work well with my 1.03, but not always, i have sometimes had to change to the Beamer.
Rolf
tirosh
Echostar AD3600IPVA
Channel Master 1.2M
VxMulti, MM1.04
Essex
Thanks for the suggestion Rolf. Will give this a go.
As an aside I notice that the order of the providers is not the same in the different files. Does this make any difference? For example should Kiosque be in position x in a particular file?
Tirosh.
Yes Tirosh, I've read a couple of threads in NGs about that, but normally it's on the 3 in 1 cards. May be worthwhile trying a copy with it placed further up the pecking order.
Rolf
tirosh
Echostar AD3600IPVA
Channel Master 1.2M
VxMulti, MM1.04
Essex
Rolf,
I'll try a few combinations and let feedback what happens.
Tirosh.
