wium said:Topper i did mention that it is a Technomate 2600 sat motor.The motor is Diseqc H to H and i have a 90CM Aluminium dish.
cocker80 said:Think the attached image is what you are after. Better late then never ;0)
Channel Hopper said:Very informative Cocker.
Just out of interest, are the instructions you have posted in the manual that comes with the motor, and do you know if these mechanical limit sliders have been known to fail, move in transit, or move once installed ?
cocker80 said:Yep the image is from the manual that came with my 2300, but should be the same as the 2600. There is a screw on the sliders that allows you to lock them into place. I can scan the manual and upload it if you require it?
