I am using a Dreambox 7025 with dual LNB inputs. I want to replace the single LNB with a dual one (or quad and not use 2 outputs if necessary) and would like to have some recommendations on the best LNB to use on my 1.1 Triax motorised system.
The cable will also have to be changed and I understand that the better quality cable the better so what should I be using (poss 10-15m).
Many Thanks
Many Thanks
