Advice Needed LNB & DISH
bleros
Albania
SkyBox F3
AMD Phenom II X6 1100T Black Edition
Albania
Hello Satellites Forum
My dish is 120x120 cm,is fixed,so i want to recieve signal from two satellites, Astra 19,2°E and Eutelsat 16.0°E So i know i need Monoblock LNB one coax in 1 receiver , but exactly i don't know which LNB to buy is there difference small and large dish. suggest me some LNB Monoblock which working with this two satellites.
I apologize if thread is not in right section
Thanks You!
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Do not buy monoblock. Make multifeed out of 2 universal LNBs. Is your dish round? Could you show some picture?
And use Narrow LNBs (eg Alps) as "normal" ones probably will be too physically bulky to be able to attain the 3.2 degree separation required.
satelliteman
Yes, narrow feed required and will give seperation on a 120.
Sent from my Galaxy S4 GT-I9505 using Tapatalk 4
On a 1.2m reflector a separation of 3 degrees should be achievable with standard LNBs, are you sure the dimensions you have given for the dish is correct ?
bleros
Albania
SkyBox F3
Albania
Yes dish is round ! if measured like this |) is 117cm if measured from abow below dish inside ) is 120 hope you understand :)
Thanks you
RimaNTSS
N-E from Riga
I think that I have more or less same antenna, it's working area is almost round. Good dish. Very easy to make multifeeds on it. That is my set-up. Unfortunately for this dish I am going to get rid of it soon.
bleros
Albania
SkyBox F3
Albania
Yes is same antenna, yes is round working area is on the ground i dont know if i can stretch other coax bowel is small is in the ground what part need for two lnb cable how to connect to receiver
RimaNTSS
N-E from Riga
Not sure I've fully understood your last statement. here is no need to run another cable/cables from antenna to receiver. You simply attach Diseqc 1/4 behind antenna, connect all your LNBs directly to this device and only one coaxial cable will go from Diseqc to receiver.
bleros
Albania
SkyBox F3
Albania
Ok so from receiver cable goes in out in diseqc i attach photo is that diseqc OK ? and what do u think about the multifeed in photo is that ok ?
RimaNTSS
N-E from Riga
Diseqc is OK. Multifeed will also be OK if you manage to attach it to your antenna.
hairybadger
Bricoleur
46.1N 6.4E
see sig
You can also get multifeeds where you attach one LNB as per normal to the boom arm, and then the second (or nth) LNB effectively hang(s) off the first.
bleros
Albania
SkyBox F3
Albania
Hello im working on it. i got 3 LNB with 0.1db 40mm, eutelsat16 working good, but im stuck in astra19.2 here is problem. Skybox f3 receiver. so how to get channels some time without changing lnb frequency , pic in lnb frequency changing frequency some chanel work when i change lnb frequency to other freqquency current channels not work others work. thanks
LNB Specifications
Input frequency from 10.7 to 11.7 / 11.7 to 12.75 GHz
Lo Frequency 9.75 / 10.6 GHz
polarization Linear
Band switching 13 / 18V 22 KHz
Gain 50 - 65 dB typ
Current consumption 75 mA
bleros
Albania
SkyBox F3
Albania
i fix thank s;) i reflash firmware now working
