Thankyou for your advice, i have just purchased an inverto silver tech 0.2db twin output universal lnb with high performance and low noise figure. What do you think?
Just as a matter of information, the quoted Noise Figures are usually that achievable over only a portion of the Band - the Noise Figure vs Frequency plot is not constant. Nor are any of the other parameters eg Gain.
The point is, you don't often get access to a full and meaningful spec., so the best policy is to buy on reputation.
I compared today morning $8 Inverto WhiteTech 0.3db LNB and Invacom SNF-031 0.3db LNB. ABSOLUTELY NO DIFFERENCE! Same signal, same strength, same quality! Just price is $8 for inverto and $56 for invacom - 7x times higher
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
