lnb holder too small for my lnb
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
I got a 96cm andrews/channel master which looks a bit different to the rest of the andrews range. The lnb holder is too small for my standard lnb. I have a picture below of the same dish as i have. You can see how different it is.
By 'standard' I assume you mean an LNBF with a 40mm throat.
If the LNB holder is a standard 23mm type, you'll need an LNB such as the Invacom C120 or similar to fit on the feedhorn.
I had a 40mm lnb maybe not standard. thanks for your help ill order the right one.
