caphook said:
thanks for that Rai Uno i have made a cable as you suggested with still the same results, even with no meter in just connected to the LNB the signal strength is still 59-60%.
Ok.
That leaves us with misalignment (my favourite) or a duff LNB (as you suggested).
Duff new LNBs are pretty rare beasts, so I suspect your problem is due to alignment.
So, check again:
1. Pole absolutely vertical
2. Motor
Latitude scale set to 50 something (they often have a scale either side of the barcket, so make sure you are reading the right one)
3. Dish Elevation set to around 24 degrees (ish)
4. Dish mounted absolutely in line with the front of the motor stub (There should be a faint datum line for you to use.
5. LNB mounted with Zero Skew ie Dead upright with Dish pointing South.
6. Your Lat/Long correctly entered into the Receiver (Common mistake is to leave Longitude as E or +, whereas many UK residents are W or - )
7. Motor sent to Zero/Reference and Thor selected on Receiver (I'm not an adherent to the "South Satellite" philosophy, which is a relic of days gone by, but this Forum seems to abide by it ........... )
8. Alignment optimised by moving the Motor/Dish assembly as one around the Pole (for Azimuth) and by finely adjusting the Dish (not Motor) Elevation for .......... Elevation.
Which one did you forget ................ ??
And finally, wise man he always have a spare LNB to hand.
