LOF problem
ten980
dm500
Hello
Since i done a factory reset on my dreambox 500s i can't search for any channels on astra 28.2 because the dream restarts while searching and i need to know the LOF and threashold for a universal LNB 10.7 - 12.75Ghz and must 22Khz be on or off???... and the volatage on H/v or 14V or 18V
I just don't know anymore please help
Email address removed
mhku
TM Nano ~ sg2100
Midlands
Why are you messing around with those settings? Leave them as default unless you have specific reason to change them and know what you're doing.
Have you had a read through The Guide? What image are you using? Are you motorised?
And welcome to the forum :)
ten980
dm500
Hello mhku
I am using gemini project 4.2 and i have a single LNB 10.7 - 12.75Ghz (universal golden single 40mm 0.6db) non motorised and while I search channels on astra 28.2 it just switches off and restart I really don't know what to do all this happened since i have done a factory reset
mhku
TM Nano ~ sg2100
Midlands
Have you tried loading a channel list e.g. PET123, using DreamboxEdit?
It sounds like your image is corrupt or the settings are conflicting and causing your Dreambox to crash. If you have a null modem cable I suggest reflashing.
ten980
dm500
I have tried reflashing gemini 3.2 and gemini 4.1 no better i will try by uploading the channel list but does my dream has to connected to the router right now just to do a channel search?
mhku
TM Nano ~ sg2100
Midlands
It only needs to be connected to the internet to download keys, emus etc.
ten980
dm500
I reflashed it with gemini prject 4.2 I put the channel list in and then i saw the sateilite i wanted in the dreambox list astra 28.2 and it just disapeared so i done a manual transponder edit to put in astra 28.2 transponder channels and as soon as i want to input them it switched my dreambox off and restarts
Sincerely i do everything right but i don't understand why it doesn't support those transponders
Please help
ten980
dm500
All this happened since i have done a factory reset on my dream
mhku
TM Nano ~ sg2100
Midlands
Can you post a screenshot like the one attached?
If you have a PC connected to the same router as your Dreambox:
On your Dreambox:
Click Menu > 6 > service searching > satellite configuration
On your PC:
1. In a web browser type in the IP address of your dreambox e.g.
http://192.168.0.11
2. Click on Control and then Screenshot
Save the image. Create a new post here, Go Advanced and click Manage Attachments to attach the image.
ten980
dm500
Ok great i will do that tomorrow because my wife is watching her DVD
But could you send me your details of LOF for your universal LNB please
Good evening
mhku
TM Nano ~ sg2100
Midlands
My LNB settings for 28.2 are shown in the attachment in post #9.
ten980
dm500
Ok i have the same settings as you on astra 28.2 but when you select LNB 0 what LOF settings do you have?
mhku
TM Nano ~ sg2100
Midlands
As attached. Why did you amend your settings?
ten980
dm500
I have also those same settings on post 13 too
It is really strange i really don't know what to do now to be honest
Everything has just changed since i have done a factory reset on dream
mhku
TM Nano ~ sg2100
Midlands
If your dish is pointing at 28.2 and you've uploaded a channel list, you should be able to select a channel from the bouquet e.g. BBC1 and it should work.
Have you changed any other settings?
ten980
dm500
No i didn't change any other settings but the problem when i do a research on astra 28.2 it restarts the Dream all the time
I wonder if it is a hardware problem because this morning i took the dream to a sateilite shop and wanted to perform a search and the same thing happened
ten980
dm500
i have a universal LNB 10.7 - 12.75Ghz just for info
mhku
TM Nano ~ sg2100
Midlands
How old is the box? Have you run a clone checker on it?
Can you watch a channel without doing a scan?
Are you doing an Automatic Transponder scan?
ten980
dm500
Yesi do a automatic san and it scans for a bout a minute and then reboots
the dream is about 2 years old
Also how do you do a clone checker on it?
mhku
TM Nano ~ sg2100
Midlands
If it's 2 years old it should be fine.
If you added a channel list, can you watch BBC1 without scanning?
