Turok
- Apr 25, 2005
- Age
- 36
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
- Austria
Hello!
i have bought a clark tech combo plus hd 5000,that is the same modell then technomate hd 6900 super!
now i connected,it with the optical tox link cable,to my yamaha ax1 av receiver
but everytime,i swtich a channel,i got a load noice,that sounds like,a analoge receiver without signal,is this a software bug,or a hardware fault,lautest soft from june 2010 anlready installed!
on the channel serach in manual mode,i often got the error ,channel alredy exists,then i loock into the freqency list,but i dont find the channel,freqency,that i want to add manualy!
any ideas?
thx for your input!
any ideas?
thx for your input!
