Archive4
LP, now you have H on your case, figure you will get the LNB, even if I have to pick it up from anywhere in Spain!What LNB do you want?
LP, do want to see pics of sat below your length!
OK, screen dumps / images of the sat you couldn´t get before you were enlarged!Bit worried now Brian.......'LP, while I was extending your length!'...and... '¿ below your length!' ..... please explain about the pics, anything to do with sat is ok with me but length........¿¿¿???***!!!
Enjoy your fiesta tomorrow.
Hi H, ironic, just 30 mins ago ordered a dual C-Band direct from Titanium having read earlier that any type of switch would reduce the signal strength. Basically needed a dual so that i could fiddle at dish level with meter/tv etc and run the 2nd feed direct to the receiver or PC card in the house ie: negating the need to keep changing cables. If memory serves me correct you mentioned yourself in a thread that you had located a second C-Band LNBF on your dish to save the prob of all the in/out changing of the dialectric....forgive me if it was someone else but i guess that would be a more upmarket version of a simple dual feed LNBF.Not familiar with dual port C-band LNBs. I'm sure there must be some but all the highly recommended ones are singles. If you are not going to be both STBs at once, how about a "smart priority switch"?
Nice set up thanks H for the descriptive pics, helps, position LNBF scaler etc.Yep, I've got two C-band LNBs on my 1.8m motorized dish. One L/R and one H/V. Plus a Ku LNB. I made the scalars interlocking to get them closer to focal point. L/R is at focal point and H/V is pointing a little further west.View attachment 76036 View attachment 76037 View attachment 76038 View attachment 76039
Hi Brian.....hope all is well.OK, screen dumps / images of the sat you couldn´t get before you were enlarged!
Don´t give him that idea! The impossible I can do now, miracles take a little longer!57E to 58W here.
John you really need a polar mount.
