Magic cam AV blocking problem
geeveeraj
Hai every body!
While watching Zee network - services like zee news, alpha punjabi, alpha gujarathi, zee cinema... (asiasat 3s Freq:4140Mhz, symbol rate:27500, vetical - originally it is mediaguard scrambled services) with magic cam version 1.04 with pentacrypt latest version, the scrambling stop and start again frequently. I tested with joker cam also, it has the same problem. I have humax FTA+CI receiver. But top field receiver is working good.
It is not depend on only zee network services. If we try for some other mediaguard services also gave same problem.
Any suggestion please!
Probably nothing you can do aside from wait for a new version Pentacrypt, some receivers are obviously OK, others not, have you trued putting the CAM in the other slot?
