Vipersan
Emmett Browns Ghost
- IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Many of my homebrew Ka feeds have odd and non uniform mounts and collars ..
This makes the precise positioning needed for Ka very difficult as they cant be laterally adjusted for optimum signal..
Well today I got lucky and found a polythene screw top bottle in my mums medicine cabinet ...which looked like it might be right.
I nicked it and checked with the callipers ..yep 39.8 mm diameter.
Perfik..
I wish I could find some more of these ...
So called 40mm upvc waste pipe is actually 41mm and thus too wide..
Anyway ..
I have one feed ready to pot up with liquid plastic ..just as soon as the epoxy resin seal has hardened completely..
Here are a few before pics ..
You'll get the idea..
I'll post another when completed.
rgds
VS
Perfik..
Anyway ..
rgds
VS
. They do waste pipe that has to be glued not the push fit type but I am unsure of the size of it,
