Manual install problem
DishDick
Gran Canaria
Having managed to do a basic card share at home (3 500S clone boxes) using CCcam, I have moved on to Oscam and CCcam. As I couldn´t get an addon from PLI for the Oscam CCcam I reflashed box with Darkstar and got it working. I am happier with PLi, so I have flashed the box with the latest beta image and am trying to install a Oscam CCcam download on it. Whatever I try does not seeem to work. From what I understand you put the tar.gz file in the tmp folder of the dreambox change attributes to 755 and run manual instal. It never works for me.
Is there a good instruction I could follow also to be sure I am using the correct file could someone kindly give me a link to a good combined Oscam CCCam file for my box and a good Oscam DVBAPI file (full file not just bin).
(The errors I keep getting are similar to "Requesting action upgrade for package 'software name' free space in /var : 2284 kb package needs: 1164 kb Error installing package" Don´t see why there is an error if there is more space than the size of the file.)
OK last try.
I have unzipped the file and manually added the files to where I think they should go to. Afetr reboot, I go into Softcam set up then default softcam, but there is only "none" showing. How do I select the Oscam CCcam. Is there a script I need to modify?
The files I have are as follows
VAR/BIN
CCcan_2.1.3 755
Firewall.sh 755
OSCam_1.0 755
VAR/SCRIPT
CCcam_2.1.3_cam.sh 755
CCcam_2.1.3_oscam_1.00_cam.sh 755
VAR/UNINSTALL
CCcam-complete_2.1.3_delfile.sh 755
VAR/TUXBOX/CONFIG
(all 644)
Oscam.ac
Oscam.cert
Oscam.conf
Oscam.dvbapi
Oscam.guess
Oscam.ird
Oscam.provid
Oscam.server
Oscam.services
Oscam.srvid
Oscam.tiers
Oscam.user
